Engine Mechanical problem
1980 Mazda RX7 Two Wheel Drive Manual 90000 miles
You guys helped me solve a problem with my carb - thanks so much. I cleaned it up as advised and everything seems to work fine now.
I do have another question. The carb used to flood occasionally (that was the reason I took the carb apart many years ago). If I turned the ignition on & looked into the carb, I could see fuel just pouring into the carb through the main jets. I kept checking/replacing the needle valves and floats, but never found or solved the problem. This time I tried looking for anything that would increase the fuel pressure, so I disassembled and cleaned the fuel inlet and return assembly and paid particular attention the the small hole in the part inside that assemble called the "adapter". I didn't find any dirt, but could that be the problem?
May 9, 2010 at 11:45 AM
