New battery-new alternator-good 80 amp and 30 amp fuses
1980 MAZDA PROTEGE
MIRICO
Good clean connections on a 1990 Mazda 4dr Protege but still won't
put 60-65 amps in the battery or 14+ volts. Idiot charging light works.
When I charge it with a trickle charger it will run for approximately 3 days.
And it will run if you jump it.
[b:c0b57da47a]I have been told to check for a fusible link. But I don't want to tear the
wiring harness apart to find it.[/b:c0b57da47a]
[b:c0b57da47a]Can you tell me precisely where it is and if it a thin wire or a real fuse?[/b:c0b57da47a]
The guy at the parts store says the alternator is good but I am not getting the
juice back to the battery for storage.
When put on the trickle charger it starts and runs normally and will continue to run as long as I don't fire up the high beams and put the heater on 4.
The 15amp fuse inside the car is "ok"
Please help I need the automobile asap.
Thanks a million!
and Warm Regards
mirico
Jan 18, 2006 at 8:05 PM
10FOTUCK
  • 28 POSTS
Take it to an electrical shop where they rebuild alternators and let them test it and the the battery. Just because its new doesnt mean a thing. Battery could have a dead cell or a diode burned out in the alternator. It is probably remanufactured so there you go. I dont trust the auto parts store because alot of time employee doesnt know what he is doing or whats good or not good.
Jan 19, 2006 at 11:30 AM
LTM21964
mirico, just wanted to let you know that I have replaced the battery on my 1990 4dr Mazda Protege with, one new and two others that showed to be good. The alternator was replaced with a new Bosch alternator once about two years ago, and has subsequently been changed two more times with new lifetime warranty Bosch alternators as well. The car is doing exactly what you described. It can sit for several days and start perfectly. If the battery has discharged at all the battery shows to be charging and the alternator is putting out fine and will fully recharge the battery. As long as it sits there it runs fine and the voltage makes no remarkable changes; UNTIL you turn on the headlights or turn on the blower fan. One other thing that it will do is even if you do not turn on the lights or blower but instead take it down the road it will go about 2 miles and be completely discharged and will rapidly die. I am still working on the problem. I am thinking of changing the complete engine wiring harness, at least that is what a few of my mechanic friends thought might solve the problem. If you know what fixed yours I would sure like a response from you or anyone else with this problem.
Thanks
Lloyd
Jan 28, 2011 at 6:10 AM
