2003 Mazda Protege rear brake drum removal
2003 MAZDA PROTEGE
143,000 MILES • 4 CYL • FWD • AUTOMATIC
FBMUSTANG1969
How do I remove the rear brake drum?
Feb 17, 2008 at 9:02 PM
ROWTIEAR
  • 91 POSTS
There should be 2 - 8mm bolt holes on the front side of the brake drum, simply screw a couple of 1" bolts in the holes and press the drum off.
Feb 17, 2008 at 9:26 PM
FBMUSTANG1969
Sounds easy enough, but those two screws in the side face of the drum didn't budge! Any suggestions?
Feb 21, 2008 at 8:44 PM
DARKSHADOW
You might have to use an impact wrench with a Phillips bit to get those large screws out, the constant heating and cooling of the drums almost 'seals' them in. Be careful with a hand screwdriver or cordless drill/driver, you can strip them real easily.
After that, just hit the drum with a small sledgehammer firmly on each side a couple of times and drum should come off. I have found using the holes in the drum opposite the large screws don't work great as the force needed to get the drum off countering it with screwing something into it tends to strip the threads in those holes.
Feb 28, 2008 at 6:43 PM
