2003 Mazda Protege ABS and Break light are on
2003 MAZDA PROTEGE
78,450 MILES • 4 CYL • 2WD • AUTOMATIC
SNDR31PLY2
I was wondering if you could tell me what might be wrong with our car. The break and ABS light are on and they will not turn off. We changed the front branks to see if that was the problem but it still remained on. Is this something I should be worried about. And do you know how we can turn it off.
Jun 13, 2008 at 9:12 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The ABS system has logged a fault and you will have to get a scan done to identify the code. The ABS will be in-op until it has been repaired.
Mark (mhpautos)
Jun 14, 2008 at 4:11 AM
KHLOW2008
  • 41,814 POSTS
Hi sndr31ply2,
If both lights remains on all the time after starting, then follow what Mark (mhpautos) recommended.
When the brake fluid indicator light remins on while driving, the ABS light will come on. Check brake fluid level, level switch or hadnbrake switch.
Jun 15, 2008 at 10:10 AM
