Transmission problem
1997 Mazda Protege 4 cyl Two Wheel Drive Automatic
My 1997 mazda protege will not shift out of park. I have tried the emergency button to release the shifter. Also I have removed the cable and it has freedom of travel. The Shifter will shift out of park when the cable is disconnected. The Brake lights do not come on now. I replaced the brake light switch and still no luck. The switch has voltage and their is continuity back to the light bulb. Could the shift lock actuator be causing this or is it a relay. Any idea's appreciated.
Thanks!
Thanks!
Nov 5, 2009 at 3:07 PM
