1997 Mazda Protege right front window
1997 MAZDA PROTEGE
YUSETHIS
Electrical problem
1997 Mazda Protege
right front window will go down but not up (neither switch works) unfortunately the window is now stuck down. Any suggestions on what is exactly wrong or at least how to get the window back up? or where can i get a wiring diagram for it ?
Nov 16, 2009 at 3:41 PM
KEVIND65
  • 8 POSTS
Take inside door panel off peel plastic protection back so you can unscrew glass window from window regulator close to bottom of door, (two screws)then pull window up and have someone hold window or use tape to hold up then place a old broom stick cut to size, to hold up glass
Sep 23, 2012 at 11:40 AM
