1997 Mazda Protege blower motor resistor
1997 MAZDA PROTEGE
200,000 MILES • 4 CYL • FWD • MANUAL
JPENNICK
My fan had only been working on 3 for several months if you turned it to for it went off.then it quit working all together a week ago.I have replaced the blower motor resistor with one from a junkyard and it still does not work.is there another fuse or something I may have missed.Is there a way to straight wire around the resistor to check if that is the problem?Did I just get a bad part maybe?
thanks
Nov 8, 2010 at 5:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if the resistor was at fault then the high setting would actually be the one that works and the other settings would not so i would not be looking at a bad resistor. may want to check the control panel , ensure wiring is good.
Nov 8, 2010 at 5:20 PM
