i hooked up the battery backwards and then hooked it up right and now the car wont start at all what is wrong?
Aug 25, 2009 at 6:35 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
You will have to check all the fuses and any fusible links at the battery, if all are ok you may have spiked the ECU, also run a scan to check for any unresolved fault codes,start here.
