1994 Mazda Protege radiator
1994 MAZDA PROTEGE
JOHNR289
Engine Cooling problem
1994 Mazda Protege 4 cyl Two Wheel Drive Automatic 120.00 miles
how to replace the radiator
Oct 30, 2010 at 1:52 AM
KHLOW2008
  • 41,814 POSTS
Hi johnr289,
Removal
Remove Air intake duct.
Drain coolant.
Disconnect upper and lower radiator hoses.
Disconnect oil cooler hoses.
Disconnect cooling fan wire harness couplers.
Remove holding bolts.
Remove radiator.
Remove cooling fans from radiator .
Installation.
Reverse removal procedure.
Top up with coolant.
Run engine for 5 minutes and turn off.
Top up coolant as and when necessary while running.
Oct 30, 2010 at 11:33 AM
