1994 Mazda Protege please help me!
1994 MAZDA PROTEGE
116,000 MILES • 4 CYL • FWD • AUTOMATIC
RUBYNSMITH
WELL I'M REMOVING THE DRIVE SHAFT AT THE END OF THE DRIVE SHAFT WHERE IT IS CONNECTED TO THE TRANS AXILE,BROKE OFF INSIDE THE TRANS AXILE AND HOW DO I FIX THAT?THANKS FOR YOUR TIME SINCERLY RUBYN SMITH!
Jan 30, 2009 at 3:46 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If you remove the other drive shaft you may be able to look through past the spider gear and tap it out with a long thin pin punch, otherwise the transmission will have to be removed and dismantled.
mark (mhpautos)
Jan 30, 2009 at 5:01 AM
