Fuel pump wiring
MAZDA
ROCKETMAN
My Mazda Familia 90 converted Gtx (TURBO) has a problem with it fuel line or wiring. Every now and then the car stopped. after mucking around with it we thought it was the fuel pump as it was a standard non turbo pump running for a turbo engine, so we got one for a turbo car and installed it checked it out fuel was getting pumped and it went. Couple weeks later the same thing happen it just stopped, and then a couple of weeks later it was able to start, and lasted for a week until it did the same thing again. This time i checked the voltage of the pump it was reading 11.7. What would be causing the loose of power and any idea on how to fix it?
Why would it go for a week and then stop for a couple week and then without out fixing it, it would start again??
Jan 29, 2007 at 6:28 PM
[quote:57e6283a17="rocketman"]My Mazda Familia 90 converted Gtx (TURBO) has a problem with it fuel line or wiring. Every now and then the car stopped. after mucking around with it we thought it was the fuel pump as it was a standard non turbo pump running for a turbo engine, so we got one for a turbo car and installed it checked it out fuel was getting pumped and it went. Couple weeks later the same thing happen it just stopped, and then a couple of weeks later it was able to start, and lasted for a week until it did the same thing again. This time i checked the voltage of the pump it was reading 11.7. What would be causing the loose of power and any idea on how to fix it?
Why would it go for a week and then stop for a couple week and then without out fixing it, it would start again??[/quote:57e6283a17]
Try this if it has one fuel pump relay-also check the ground circuit
Jan 30, 2007 at 2:23 AM
ROCKETMAN
[quote:a53a006aaf="rasmataz"]
Try this if it has one fuel pump relay-also check the ground circuit[/quote:a53a006aaf]
if you dont mind me asking. whats the ground circuit.
with the fuel relay i took that out and hooked up to a 9volt battary and i check out it click on and off. and current going through it, so i thought the relay was ok
Jan 30, 2007 at 12:15 PM
[quote:dbead4ea88="rocketman"][quote:dbead4ea88="rasmataz"]
Try this if it has one fuel pump relay-also check the ground circuit[/quote:dbead4ea88]
with the fuel relay i took that out and hooked up to a 9volt battary and i check out it click on and off. and current going through it, so i thought the relay was ok[/quote:dbead4ea88]
The ground for the pump-might be a bad connection
Jan 30, 2007 at 1:15 PM
