1994 Other Mazda Models overheating
1994 MAZDA
135,000 MILES • 4 CYL • FWD • AUTOMATIC
KIRSTYLEEC
Hi I recently flushed coolant and replced with new good quality engine coolant and 4 weeks later my car has started overheating again, temp gauge on my dash is almost at hot, smoke coming from under bonet and its hissing(sounds like fireworks) Im semi mechaniclay minded but am freaking out with what might be wrong. I have to put water into radiater and the overflow tank to keep temp down. can you help me diaognose the problem? I would like to try fix myself to save money!
Thank you.
Nov 10, 2008 at 5:25 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
Replace the thermostat if not already done, check if it is opening, have the radiator cleaned & flow tested, make sure that the fans are working, start here.
mark (mhpautos)
Nov 11, 2008 at 5:18 AM
