Re: 1994 Mazda MX3 1.8 lt V6-
Starting and backfiring problems-
1. Until recently, the care never started in humid or severely cold conditions. Each plug was receiving a strong spark, the plug wires were good and there was fuel. The engine doesn't burn oil or coolant. Two days ago, I discovered moisture beneath the cap and severe rust between the igniter and coil. I cleaned these as best I could (w/dremmel wire brush) and replaced the heavily worn and cracked gaskets, I replaced the cap and rotor and reassembled it and it starts in any weather. I solved the starting problem, but another problem persists.
2. When the engine reaches operating temperature, it begins to backfire and stall below 2200 rpm. If I feather the throttle in 1st gear using the shift " hold" button (automatic tranny) and coax the engine above 2200 rpm then it runs, but below 2200 rpm it backfires and stalls. During highway driving, I cannot accerate above 4,000 rpm without the same problem occuring.
This problem never shows itself when the engine is cold.
Thanks in advance,
Marc
Thanks in advance,
Marc
Jan 13, 2008 at 5:27 PM
