1992 Other Mazda Models Overheat, High Idle
1992 MAZDA
150,000 MILES • 4 CYL • FWD • AUTOMATIC
DEREK_HART
After a relatively reasonable start up, I can drive my Mx-3 about for around 2 minutes before it begins to overheat. After 5 minutes, a foul burning-rubber smell can be detected. The car will take 2-3 hours cooling. I've never tempted the car beyond this.
So, naturally, my question is what may be the cause of the overheat, and how I might begin fixing it.
The car also suffers from a high idle, but nothing as voracious as the overheat. Is it related in some way? How can I diagnose this problem as well?
Feb 28, 2008 at 11:50 AM
LEGITIMATE007
  • 5,121 POSTS
the overheating can be caused by a bad engine coolanat temp. sensor or a bad thermostat. your high idle can be caused by a vacuum hose leak a dirty throttle plate , a bad throttle position sensor , even an idle air control valve. on the overheating I would start with the thermostat, on the high idol I would start with checking the vacuum hoses for leaks or possibly being unhooked.
Feb 28, 2008 at 12:29 PM
