1995 Mazda MX6 New starter grinding on flywheel
1995 MAZDA MX6
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
RJAYBIRD62
Upon engine reinstallation and attempting to start, starter gear hangs up on flywheel and makes terribe noise. This is a brand new starter. What could be causing this?
Oct 10, 2008 at 8:16 PM
MERLIN2021
  • 17,250 POSTS
Usually happens if the starter isnt flat against the mount(loose).
Oct 10, 2008 at 8:37 PM
RJAYBIRD62
I checked the mount and it is flat and tight. I'm wondering if I have the wires connected correctly to the solenoid. Could this be the issue?
Oct 10, 2008 at 8:56 PM
MERLIN2021
  • 17,250 POSTS
yes and ignition switch, or the starter relay, or the starter itself may have an internal short, did you have it tested before installing it?
Oct 11, 2008 at 9:21 PM
