1995 Mazda MX6 Car will not start
1995 MAZDA MX6
100,000 MILES • 6 CYL • 2WD • MANUAL
WATSX2
I purchased a car from a guy I worked with because the voltage regulator went out.(That's what he was told by NAPA) I purchased a new alternetor with a new voltage regulator and put it on the car.The car will turn over but will not start...what else can I check to get this car running??
Jun 30, 2009 at 3:26 PM
You need to check if you're getting fuel and spark get back asap.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Jul 9, 2009 at 7:12 PM
