1989 Mazda MX6 clutch
1989 MAZDA MX6
250,000 MILES • 4 CYL • FWD • MANUAL
JFENN1966
clutch pedal is sticking to the floor it will go in gear but pedal wont return
Dec 16, 2009 at 5:31 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have run out of clutch fluid due to a leak at the master or slave cylinder, check under the rubber boot on the slave for fluid, and look under the dash where the clutch pedal connects with the master cyl, check both for leaks, replace faulty components and re bleed system.
mark (mhpautos)
Dec 17, 2009 at 12:15 AM
