clutch pedal is sticking to the floor it will go in gear but pedal wont return
Dec 16, 2009 at 5:31 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
You will have run out of clutch fluid due to a leak at the master or slave cylinder, check under the rubber boot on the slave for fluid, and look under the dash where the clutch pedal connects with the master cyl, check both for leaks, replace faulty components and re bleed system.
