having trouble with my 1995 mazda mx3. i just got done rebuilding the engine and have been battling a power loss with this car for some time. i replace the clutch, getting 190psi per cylinder, ignition is right at 10 degrees. replaced alternator, air filter, fuel injectors, MAF sensor, TPS sensor, temp sensor, 02 sensor, distributor, cap, rotor, spark plugs, plug wires. fuel pressure tested fine but have not yet tested the fuel pump it self. Catalytic converter tested fine. not sure what else to check it lags on the highway very bad and just not up to power. thanks
Jon
Jon
Jan 3, 2007 at 12:05 AM
