Mazda MX3
MAZDA MX5
MELISSA
I was recently told that I will need new brake lines, and fuel lines in order to sell my car saftied. Is this worth doing? There's not much else wrong with the car, it's a 93 with about 136 000km's. Any advice, or places to get cheap parts would be helpful as well
Thanks
Jan 11, 2006 at 11:17 AM
2CARPRO JACK
  • 11,533 POSTS
Why do you need the lines? They are designed to outlast the car, Other than the rubber hoses
Jan 18, 2006 at 5:43 PM
COSMO
  • 347 POSTS
Alot of time the brake lines on mx-3's will rott out just before they go over the gas tank at the back. Since the fuel lines run along here too, there is a good chance that they are rotten too. I would think that the brake lines are more of a problem than the fuel lines at the moment, unless it is leaking fuel. Brake lines can be called as a safety hazzard (Here in Canada) if they are 'heavily rusted' and still not leaking. If they are leaking or even just seaping a tiny bit...then they need to be replaced. A GOOD shop will replace them from front to back, as repairing a line or splicing is NOT considered acceptable for a safety (again here in Canada) but is acceptable as a repair (NOT a Saety).
BTW 2carprojack....you never repaired a line on a car? And who uses rubber line on a car with 50 psi coming out of the pump? How you gonna secure that line to the steel line, hose clamps? Butcher
Cosmo..Mazda Tech
Jan 18, 2006 at 10:07 PM
