Engine Cooling problem
1999 Mazda MX5 Two Wheel Drive Manual 62000 miles
Hi, had a gasket replaced at the back of the engine as i had a water leak under pressure. Now when i try to start it up water just blows back through the system and if you remove the radiator cap blows right out. Car won't start. is it the head gasket and should i have it repaired or just replace the engine?
Thanks, Lynne.
Thanks, Lynne.
Dec 30, 2008 at 11:35 AM
