1992 Mazda MX5 power windows
1992 MAZDA MX5
200,000 MILES • 6 CYL • FWD • AUTOMATIC
MARLIS PRIDEAUX
how do you install the WR NAO2 410
ABMCI Japan
862100-3821 11
12 v 7E
for the power windows
I can't understand the adjustment process
Sep 9, 2008 at 10:02 PM
KHLOW2008
  • 41,814 POSTS
Hi marlis, Thank you for the donation. Seems quite a complex situation. VERTICAL DOOR GLASS ADJUSTMENT 1. Remove the weatherstrip, and check the alignment with the door glass in the fully closed position. 2. Loosen upper stop installation bolts (A). See Fig. 3. Adjust by moving the upper stop up, or down so that the upper edge of the door glass is in the correct position, and then tighten bolts (A). NOTE: When the door glass is raised, both glass stops must contact the upper stop simultaneously. Before an upper stop is moved for adjustment, lower the door glass slightly.
https://www.2carpros.com/forum/automotive_pictures/192750_PWindow92MazdaMX501A_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PWindow92MazdaMX501B_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PWindow92MazdaMX501C_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PWindow92MazdaMX501D_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PWindow92MazdaMX501E_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PWindow92MazdaMX501F_1.jpg
Will attach more details asap.
Sep 10, 2008 at 3:05 PM
