I have noticed in the past couple months my clutch fluid has been just under max. It's been about a 1/8th or a 1/4th of an inch under the max line. I read in the instruction manual, to make sure it's always at max. That gave me the impression that the clutch fluid has a reason to get low. Does clutch fluid burn off from driving? There doesn't appear to be a leak as there are no spots on the ground after I've parked. I've added more each time and now I check it more often. Is there any other reason you can give me for the fluid loss?
Aug 25, 2009 at 5:43 PM
