1995 Mazda MX3 my mazda bogs
1995 MAZDA MX3
LAXANDSLACKS
Engine Mechanical problem
1995 Mazda MX3 Manual
my car will staqrt to bog a when idling and then when i drive it will bog if im giving it gas while i drive its usually fine in forst and second gear but once i get up to 4 and 5 it is a problem any ideas?
Feb 26, 2010 at 1:44 AM
If the clutch is not slipping
Inspect and test all the following listed below:
I know its a long list but one of them can caused your problem
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 26, 2010 at 1:52 AM
