1993 Mazda MX3 horn
1993 MAZDA MX3
JSOLIS19
Electrical problem
1993 Mazda MX3 4 cyl Manual
Hi I have a '93 Mazda MX-3 in which the horn is inop. I checked the fuse, good, and I hear a clicking in both the relay and the button when pressed. Can it still be either/or? How do I test each component?
Mar 26, 2009 at 5:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to test the horn itself. Supply power to the horn manually with a power wire. If horn does not sound then suspect faulty horn. If horn does sound then first try swapping out the relay with a known good relay.
Post results and I will follow up.
Thanks for using 2CarPros.com!
Mar 27, 2009 at 2:10 AM
