1992 Mazda MX3 wont crank
1992 MAZDA MX3
140,000 MILES • 6 CYL • FWD • AUTOMATIC
DDL1170
Car was running great, I switched it off went back to it. It will only turn over as usual but wont crank. I have fire at all cylinders, with 150lbs of compression on each cylinder,with this car I need help
Dec 6, 2009 at 8:15 PM
MHPAUTOS
  • 31,937 POSTS
Hi there thank you for the donation,
Have you check for injection pulse, this is best done with a noid light or an LED test light, also have you checked fuel pressure and flow, do this and a scan to check for any unresolved fault codes and re post your findings for further assistance.
Mark (mhpautos)
Dec 6, 2009 at 9:27 PM
