1992 Mazda MX3 Clutch noise
1992 MAZDA MX3
160,000 MILES • 6 CYL • FWD • MANUAL
XTREME1
  • 4 POSTS
When i press on the clutch, it makes a noise but, the gears go into 12345 smoothly.
what is this symptom? is it just needing an adjustment or a clutch replacement?
Sep 23, 2008 at 3:07 AM
I'd say a clutch assembly replacement that involves the release bearing or the pilot bearing/bushing
Sep 23, 2008 at 4:04 AM
XTREME1
  • 4 POSTS
Hafa Adai!
Thank you. now its idleing up and down when in neutral. what can be the problem?
Sep 23, 2008 at 8:17 PM
Hafa Adai to you too and To do mauleg from Sin City
Chelo-this one can give the Taotamona nightmares, sorry for the grocery list, I'll be here if you need more
Okay-check the fuel pressure if its within specs and then start checking the idle air control valve,airflow sensor,throttle position sensor, EGR and PCV valves, O2 sensor and vacuum leaks-double check all sensors connections
Sep 24, 2008 at 1:28 PM
XTREME1
  • 4 POSTS
[quote:4a97e7e4f5="rasmataz"]Hafa Adai to you too and To do mauleg from Sin City
Okay-check the fuel pressure if its within specs and then start checking the idle air control valve,airflow sensor,throttle position sensor, EGR and PCV valves, O2 sensor and vacuum leaks-double check all sensors connections[/quote:4a97e7e4f5]
Si yu'us ma'ase chelu! yeah, I found out it was the AIC valve. Sorry for the late reply, and hope you had a wonderful Easter!
Apr 14, 2009 at 2:50 AM
I hope yours went well too-comeback when you need help again-Adios chelu
Apr 14, 2009 at 3:39 PM
XTREME1
  • 4 POSTS
[quote:61171edba8="rasmataz"]I hope yours went well too-comeback when you need help again-Adios chelu[/quote:61171edba8]
Chelu',
I have another qquestion, if you dont mine, answering for me? I also have a 96 Accord v6 with transmission sleepage. What could be the problem, and is it worth fixing or rebuilding/replace? thanks!
Apr 15, 2009 at 12:39 AM
The transmission fluid is it in the full mark when warmed up and fluid condition is okay?
You can try flushing or just replace fluid and filter and see what happens. Also check the throttle position and vehicle speed sensor.
Apr 15, 2009 at 4:23 PM
