MPV won't shift
MAZDA MPV
RHODEBACK
Hello All,
First time poster.
2000 Mazda MPV LX. 79K, A/T, 3.0L
Problem just started. Won't upshift or downshift. No speedo (electronic) and missing the pointer for the shift indicator. ATF is full, pink and doesn't smell burnt. I can upshift manually...and it only will downshift manually when stopped. Goes to neutral if I try to downshift when moving. I already changed the inhibitor switch because of the missing pointer on the shift indicator. It didn't help.
Thanks for any assistance.
rhodeback
Jan 16, 2007 at 12:27 AM
COSMO
  • 347 POSTS
HAve you checked all the PCM and TCM fuses? Also check all teh connections at the PCM and TCM
Cosmo...Mazda TEch
Jan 16, 2007 at 6:07 AM
RHODEBACK
[quote:0110691094="Cosmo"]HAve you checked all the PCM and TCM fuses? Also check all teh connections at the PCM and TCM
Cosmo...Mazda TEch[/quote:0110691094]
I don't have a service manual yet. Will be picking one up soon. Can't afford the factory one...big $$$...so I will probably get a Clymer's or Hansens (?)
Thanks for your prompt reply, I'll let you know if I find anything.
rhodeback
Jan 16, 2007 at 7:04 PM
