1998 Mazda MPV engine hesitation and stopping on deccelerat
1998 MAZDA MPV
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
STUBBIE64
mazda hesitates while driving and stops when deccelerating
Dec 31, 2009 at 9:12 AM
Could be one of the following:
Oxygen Sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Coil and Rotor
Jan 1, 2010 at 6:46 AM
