1992 Mazda MPV FREEZE PLUGS?
1992 MAZDA MPV
14,500 MILES • 6 CYL • AWD • AUTOMATIC
TMEPEANUT
Where are the exspansion plugs located? Recently belt to fan/alt. broke while driving,engine over heated. Replaced belt put water in,but water is now pouring out at rear of engine. Visual of rear (of block) is so tight can not be sure where water is coming from.No condensation in head(oil,not milky)no oil in radiator.after filling w/water heater blower works fine temp. is normal, but crawled under neath and water seems to be pouring out of rear of block or engine? No cracks can be seen in block, do to limited vision of area.
HELP
Jan 23, 2009 at 1:27 AM
If its actually coming from the back of the engine-to get at it-you have to remove the transmission
Jan 23, 2009 at 1:49 AM
