Would not start 5 minuets after just running. Shows no spark. Cant,hear fuel pump running prior to ignition. plugs are dry. turns over fine. Can't find emergency fuel pump shut off. Would fuel pump not running cause engine control to disable spark? All fuses - relays are good.
updated 9/4/09
OK: Where is that component (CKP) located in the engine compartment so I can check it? Brad
updated 9/4/09
Sep 3, 2009 at 9:00 AM
