2001 Mazda Millenia TCS
2001 MAZDA MILLENIA
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
PEETE
Thanks in advance for taking my question, the traction control light is coming on and TCS on in red letters and while driving it is activating as if control was needed.A little history,just had the catylitic system replaced and have been using regular gas instead of premium,don't know if its related or not.
Jun 30, 2009 at 7:34 AM
EXTRUDEDCOW
  • 27 POSTS
[quote:20d5724155="Peete"]Engine Mechanical problem
2001 Mazda Millenia 6 cyl Two Wheel Drive Automatic 130000 miles
Thanks in advance for taking my question, the traction control light is coming on and TCS on in red letters and while driving it is activating as if control was needed.A little history,just had the catylitic system replaced and have been using regular gas instead of premium,don't know if its related or not.[/quote:20d5724155]
Is this the supercharged model? If so, switch back to premium. Using regular gasoline is likely to cause performance problems and engine damage if you continue to use it in the supercharged model.
Unfortunately, the TCS system is quite touchy in the Millenias. A failing engine sensor, vacuum leak, or misrouted vacuum line can both trigger a TCS malfunction. Assuming this is the supercharged model, I would start by switching back to premium then checking the vacuum lines. If the problem persist, you may need to dig deeper to find a solution.
Jul 10, 2009 at 3:58 PM
