1999 Mazda Millenia "Hold" Light on dash
1999 MAZDA MILLENIA
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
LGAIENNIE
What does the "Hold" light indicate? It just came on while I was driving. Turned the car off and restarted - "Hold" is still on.
Thanks for quick reply.
Oct 11, 2008 at 9:01 PM
2CARPRO JACK
  • 11,533 POSTS
The "HOLD" light is an indicator that the PCM has recorded a fault in the trans or speed sensing circuit. You need to have it scanned to see what is wrong.
Oct 11, 2008 at 9:42 PM
EXTRUDEDCOW
  • 27 POSTS
The hold light can also indicate you have pressed the Hold button on the gear selector. It allows you to force the transmission to stay in the selected gear (will not downshift or upshift unless absolutely necessary), and is easily pressed on accident if you're not aware of it. It can be useful for engine braking down steep hills, but you'll generally want to leave it turned off.
Oct 28, 2008 at 9:09 PM
