1998 Mazda Millenia starter
1998 MAZDA MILLENIA
ANGTRAVIS
1998 Mazda Millenia
my old starter was tested and it was bad so i bought a new one.now the new one is on it still want crank, it only acts like it want to crank but will not. what else could be wrong???
Nov 9, 2010 at 9:11 AM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem,Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Nov 10, 2010 at 1:39 AM
