1995 Mazda Millenia Major Oil Leak
1995 MAZDA MILLENIA
SPOKIDOKES
1995 Mazda Millenia 6 cyl Automatic
I Just Recently discovered what i think is a major oil leak in my car.The Oil only leaks out when the car has been running and after it's parked it'll produce a puddle under the area where my oil pan sits. my uncle and myself took a look thought we found the source of the leak to be the seal on the oil pan, which is easy enough to fix. I've made sure to keep Oil in there and i go to pick up the part later today. However, when dropping off a friend this morning for work, he took a look since my car started producing smoke due to extra oil leaking onto the engine. He's ASE certified and he briefly mentioned something about a valve and the leak being higher than the pan and that's why there's oil burning on the engine. When i Looked at it with my uncle, i Literally watched oil drip from between where the seal should be on the oil pan so i'm positive that needs to be replaced, but what else could be causing such heavy leaking? It's a 1995 Mazda Millenia and i haven't had any problems with it before now. There's also a Belt squeak that's started, partially because i think it's saturated with oil. any Advice on what needs to be replaced? and is it possible to do it myself with the right parts?
Jun 14, 2008 at 10:14 AM
KHLOW2008
  • 41,814 POSTS
Hi Spokidokes,
The oil pan gasket tends to harden over time and will leak. Test and see if the tightening screws seems loose. If they are, the leak from the gasket can be quite bad.
Behind the crankshaft pulley there is an oil seal and that would require attention too.
Fast leakage can also be due to a faulty oil pressure switch, so if the leak is around its location, check it too.
Any leakage from above the oil pan can flow down onto the oil pan gasket and flow along the seams till it drops off at the lowest point, so don't be fooled by it.
Jun 17, 2008 at 10:55 AM
