I am using an Autoxray EZ-Read 2000. After I scan the data and press the "Mon" key, it tells me the following:
MIL Status ON
Misfire Completed
Fuel System Completed
Comp Component Completed
Catalyst Completed
Heat Catalyst Not Supported
Evaproative System Completed
2nd Air System Not Supported
A/C Refrig Not Supported
O2 Sensor Completed
O2 Sensor Heater Completed
EGR System Completed
Is that what I should have been looking for? When I select Capture Mode, O2Tests, Test Results, or Vehicle Identification under the Mon menu, I am prompted to contact Autoxray for an update. When I read the trouble codes under data is when I got the P0420 code; and there are no codes when I look for the pending codes. I appreciate your willingness to help me out and your knowledge about such matters.
Aug 5, 2009 at 10:45 PM
