1993 Mazda Miata oil around my spark plugs
1993 MAZDA MIATA
85,000 MILES • 4 CYL • 2WD • MANUAL
LETUSSARD
Hello - I just noticed while changing my spark pluge to the oem champion plugs that the cylinder closest to the firewall - the plug had oil around it - on top of the plug - I had a 93 toyota camry with the same issue but cant remember the fix - would changint the valve cover gasket be the fix? HELP ASAP!!!!
Jun 21, 2009 at 9:47 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, that is what is wrong, the gasket has lost its seal around the plug well, allowing oil in.Those 4 cyl Camrys always came loose..... You should take care of this, the coils dontlike firing into oil, it can cause premature failure
Jun 21, 2009 at 9:51 AM
