1993 Mazda Miata GRINDING NOISE
1993 MAZDA MIATA
KAT 57
Transmission problem
1993 Mazda Miata 4 cyl Two Wheel Drive Manual
There is a grinding noise like something is touching while spinning. It occurs when I downshift and sometimes sitting still. I can feel it in the gearstick, too.
Apr 13, 2009 at 8:10 AM
RICH CRITES
  • 75 POSTS
Check the gear oil level. Are you sitting still with the clutch pedal in? Does it make the noise with the transmission in neutral, or does it only make noise when it is in gear with the clutch in? If it makes the noise with it in gear and clutch in, it could be a bad throw out bearing.
Apr 14, 2009 at 12:48 PM
