1991 Mazda Miata Idle Speed
1991 MAZDA MIATA
170,000 MILES • 4 CYL • 2WD • MANUAL
JOHNOZGA
The idle sometime idles higher then normal though when I put the ac on it idles normal again.
It usually idles a guess around .5 then idles at 1.5.
Thank you for your time.
John Ozga
[email protected]
Aug 10, 2009 at 6:47 PM
Thank you for the donation
Try cleaning out the throttle plate and inspect the accelerator linkage/ binding- Also test the idle air control solenoid and airflow meter, also clean out the EGR and PCV valves comeback with some results
Aug 11, 2009 at 5:23 AM
