1990 Mazda Miata won't go, but will overheat
1990 MAZDA MIATA
JMENDOLA
I recently replaced the plugs, wires, air filter and pcv valve on my 1990 Mazda Miata with 100k miles because it was running a little rough. It helped very little, so I also replaced the fuel filter, which helped a little for a few days and then I lost almost all power and acceleration. If I put my foot to the floor, with the clutch engaged, it can take up to 10 seconds for the rpm's to get up enough so that I can go. Then I may only go a few miles an hour until it gradually lurches its way up to speed. After driving no more than 15 minutes, it will overheat.
Spark, compression, converter and fuel pressure at the filter all check out fine. The shop it's at now wants to try the fuel pump, but isn't sure that will do the trick. They say the pressure is at the low end of normal.
Does it sound like a fuel pump? COuld it be the fuel pressure regulator? Fuel injectors?
Help!!! They don't know what to do next.
Jun 6, 2007 at 2:10 PM
USNAVYVETMISSOURI
It sounds like a timing problem to me, and on this year miata the first question is: Has the timing belt been replaced yet? It is certainly due by 100k, and may have slipped on the cams. This year Miata also has a known crankshaft issue which you may want to investigate on a miata forum.
Jun 17, 2007 at 6:15 PM
JMENDOLA
Yes, the timing belt was replaced about 25,000 miles ago. I finally took it into the local Mazda dealer late last week and he confirmed that it was the key way on the crankshaft. They wanted almost $2k for a new engine. Has anyone ever replaced the crankshaft on the 1990 Miata? Anyone know where I can find an inexpensive re-built or used engine?
Thanks.
Jun 19, 2007 at 10:11 AM
USNAVYVETMISSOURI
There is a documented way to repair a short nose crankshaft issue. I suggest you go to www.miataforum.com and either do a search or ask the question there. The members will be glad to help.
I do not have all the particulars on how the repair works as I own a later model, but the information is on the above site
Jun 19, 2007 at 6:03 PM
