Cylinder number four misfire
2005 MAZDA 6
59,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
WORZELJWR
  • 4 POSTS
Hi, I keep getting a misfire in cylinder four that brings on the check engine light. I see on the internet that a common fault is the plug seals on the valve cover, but with the plugs in, when I look down the plug holes with a torch they are all bone dry. When I take the plug out of cylinder four, the plug is all black and oily looking and the same when I look in the plug hole with plug out. Fitting a new plug solves things for a while. The car does use some oil, and cannot see any bad oil leaks. This car does not have the individual coil packs on the leads, it seems to be a separate block type? Can any one give me any help please? Thanks, Jim
Jul 9, 2018 at 5:05 AM
Good morning.
The first thing that comes to mind is oil fouling from bad piston rings. Oil get by the rings and gets up in the cylinder and fouls out the plug.
Do a wet and dry compression test. Do the dry test first. Then insert some oil into the cylinder and do it again. If it raises more than 20-25 lbs, you have failed rings.
Jul 9, 2018 at 5:56 AM
