1994 Mazda b4000 most likely problem
1994 MAZDA B4000
18,678 MILES • 4 CYL • 2WD • AUTOMATIC
DIANE BRADLEY
IT wont start Until 15 minutes to hours. Problem getting worse.I have been looking on computer and it says different things and just need to know the most likey cause
Jul 15, 2010 at 5:38 AM
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it-something has to give
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 15, 2010 at 6:09 AM
