Mazda B3000 Sport. Noise started as ping while driving. Now fairly severe vibration at higher speeds or acceleration, with louder noises at all speeds . Tail shaft seal leaking. Transmission seems to be slipping as well (for some time). Pulled drive shaft. Rear U-joint is worn; front is tight. Approximately 1/4 inch vertical play in tail shaft; slightly less horizontally. No end to end play detected.
Assume tail shaft bushing worn; possibly more involved issues in transmission.
Can tail shaft bushing be replaced without removal of complete transmission?
Opinions and recommendations greatly appreciated.
Thank you very much for your time!
Oct 31, 2010 at 1:04 AM
