I have a 2001 Mazda B3000 truck with 92K miles on it. The truck is a standard with 5speed transmission. I don't drive it very much, the other day I went to drive it and there was no pressure on the clutch, the pedal went all the way to the floor. I went to check the clutch master reservior and it was empty, I filled it up and bled the clutch several times but still no pressure. The master reservior is draining when bled. I checked all the lines for leaks but there was no leak anywhere that I can see. If I push the clutch pedal all the way down to the floor, I can still start the truck but of obviously, I can't engage any of the gears. I can also start the truck in 1st, 2nd, and 3rd gear but again, can't shift into any other gear because I have no clutch. What other areas (master/slave clutch?) can I further diagnosis before spending money on a tow truck and expensive auto shop? Thanks in advance.
Nov 29, 2008 at 1:45 PM
