1998 Mazda b3000 Transmission disengages momentarily
1998 MAZDA B3000
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOMPLUM
2ce this week, after going down hill each time- the transmission disengaged. All was well, then upon leaving the stop sign- it acted as if it was in neutral for 3 seconds and took off and drove normal again. There has been no change in drivability other than this. Fluid and filter was done @ 60K. Fuid is ripe for a change again. Not burnt smelling- but losing it's redness. Level is good (actually above full as that is how the trans shop set it 6 years ago)
SO does it seem as though I am looking at a major deal or perhaps something easy?
Jun 9, 2009 at 9:32 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Best thing to do is have trans scanned for codes and solenoid /sensor operation. Problem maybe faulty sensor and not hard part failure requiring rebuild
Hope this helps
Thanks for donate
Jun 10, 2009 at 9:25 AM
TOMPLUM
Would a basic code scan say at Auto Zone also read trans codes? I d haven't had a CEL if that makes a diference.
Jun 10, 2009 at 10:11 PM
DOCFIXIT
  • 18,828 POSTS
The scan is done with a diagonistic scan tool must be done by a trained Tech. The term scanner has been misrepresented for a code reader which is what your refering to.
Jun 11, 2009 at 8:21 AM
