What I've done so far: Removed all bell housing bolts.
Disconnected tranny lines to radiator. Removed Speedometer cable. Removed Drive shaft. Removed all electrical plugs to tranny. Removed outer bolts on rear cross member but not tranny bolts yet. Pull dip stick out but having a hard time pulling fill tube. (suggestions?)
Something else seems to be holding it. I cant get it to slide back at all. Also looks like i might have to remove front cross member that has suspension arms attached
to it.(pitman arms?) And Exhaust might have to be removed. Maybe even motor mounts? Also do I need to remove torque converter bolts?
Jul 12, 2009 at 10:03 AM
