Will not turn over. New battery, new starter?
1994 MAZDA B3000
SKMWILSON
Electrical problem
1994 Mazda b3000 6 cyl Two Wheel Drive Manual 200k miles
Will not turn over. New battery, new starter, new solenoid, new battery cables, voltage transfer. What else do I need to check or replace? However, I can push it and it will start. Any suggestions?
May 20, 2010 at 9:21 AM
Check and test the clutch switch, starter relay and ignition switch
May 20, 2010 at 9:29 AM
SKMWILSON
Where is the starter relay? Is that the solenoid?
May 20, 2010 at 9:51 AM
Starter relay is on the left fender apron near the battery.
May 20, 2010 at 2:28 PM
WHEATONCS
there are only 4 relays. wot cutoff, fuel pump, pcw power and fog lamp?
Sep 28, 2024 at 6:15 PM
Here is the starter relay location and the wiring diagrams to the relay to make sure you got the right one, also, I would go over this video as well.
https://youtu.be/6YRW8fyNudY?si=qTnNNNpI9DSTvQT6
check out the images (below). Let us know what you find.
Sep 29, 2024 at 10:03 AM
