1990 Mazda b2600 turns over but won't start
1990 MAZDA B2600
142,000 MILES • 4 CYL • 2WD • AUTOMATIC
RLY222
No spark and doesn't appear to be getting fuel either (plugs are dry, not wet). Do you have any suggestions as to where to look. Whatever it is, it's common to both fuel and spark. does this truck have a crank sensor? checked all big fuses under the hood and the smaller ones below the dash with the switch on with a voltmeter and they all checked ok (voltage on both sides). Please advise.
Mar 2, 2010 at 8:14 PM
DOCFIXIT
  • 18,828 POSTS
Hi
2.2 or 2.6L carb or fuel injection? Underhood right wheel well look for test connector 1 pin Green ground. Observe check engne light it should flash so flash flash pause flash= 21. Post any codes
Thanks for donate
ECU controls spark and injectors
Mar 3, 2010 at 9:42 AM
