1996 Mazda b2300 REAR TRANS SEAL
1996 MAZDA B2300
160,000 MILES • 4 CYL • 2WD • MANUAL
TBG1550
CHANGED REAR TRANS SEAL BY THE DRIVE SHAFT, HOW MUCH FLUID TO REFILL, WHAT TYPE AND WHERE DO I PUT IT IN AT?
Feb 24, 2010 at 7:05 AM
KHLOW2008
  • 41,814 POSTS
Hi TBG1550,
Thank you for the donation.
There is a filler plug at rear cover.
Capacity is 2.4 liter ( 5 quarts ) if the oil had been drained.
If it had not been drained, filing it up till it flows out of the filler plug would be sufficient.
Grade = API GL-5 80W for temperatures lower than 0 degrees F
API GL-5 90W for temperatures higher than 0 degrees F
Feb 24, 2010 at 2:48 PM
