1995 Mazda b2300 truck while running stalled and will not s
1995 MAZDA B2300
104,800 MILES • 4 CYL • 2WD • MANUAL
G9568
TRUCK WAS RUNNING FINE STARTED TO SLOW DOWN AT LIGHT AND TRUCK STALLED, TIMMING BELT BROKE, I REPLACED BUT STILL WILL NOT START?
Feb 16, 2010 at 3:00 PM
Did you put engine no.1 piston on its compression stroke/TDC and aligned the cam and crank markings and rotor pointing to no.1 cap tower if not the valve timing is off-
Feb 16, 2010 at 3:06 PM
G9568
Yes I did to answere your reply thank you but still not starting?
Feb 16, 2010 at 3:21 PM
Are you getting spark and the correct fuel pressure?
Feb 16, 2010 at 3:23 PM
